Hello
I have tried the DB Manager but can not export
I am looking for a way to search my databases to check to see if I have the music needed for jobs.
Is there a stand alone program that will import my databases so I can search them on a PC that does not have VDJ installed.
I have 4 partions on m laptops so I have 4 databases.
I would like to have a program to read the databases and to be able to export the data to excel or access
any input would be great
Thanks
Al
Thanks
Al
geposted Tue 21 Jan 14 @ 1:45 pm
mrdjal wrote :
Hello
Thanks
Al
Thanks
Al
Hello again
does anyone have an answer to this question
looking for a clean way to export my xml file to a database
DB Manager looks like the feature is there but not finished
how much would it cost to have the export feature finished
I have seen other request about this, but no answers
Thanks
geposted Thu 03 Jul 14 @ 3:44 pm
Is there any particular reason why you don't just install VDJ and use that to search?
geposted Fri 04 Jul 14 @ 4:45 am
Yep
the reason I dont just use VDJ to do the searching is that,
I do not have VDJ setup on my home PC or work PC, plus I have 4 partitions accross 2 drives, so that gives me 4 databases to search.
I like to check to see if I have the music needed for an upcoming event, with out turning on my DJ laptop.
Plus I find it useful to be able to view a list to check for errors / typos.
Thanks for asking
Al
geposted Tue 08 Jul 14 @ 9:30 am
