I absolutely LOVE your Virtual DJ 7 Vertical 4 Deck skin, but would it please be possible to get a 2 deck version?
geposted Wed 22 Jan 14 @ 3:41 pm
And how would such a skin look like ?
I mean if you remove 2 decks from that skin, then will it be horizontal or vertical ? lol ..kidding, but cant really get your point.
geposted Fri 24 Jan 14 @ 12:14 pm
I mean take off decks 3 and 4, stretch decks 1 and 2 to fill the space where they were so that all the controls for fx, key etc on the decks are more spaced out. Also the same with the mixer.
I think the 4 deck skin is great but I only have a smallish screen resolution (1366x768) and don't use more than 2 decks, so having larger controls for the decks I do use would be a huge help.
geposted Sat 25 Jan 14 @ 10:08 am
can we see the 4 deck skin please ? :)
geposted Sat 25 Jan 14 @ 1:07 pm
@maki
info on page 4 of this thread": https://virtualdj.com/forums/174736/VirtualDJ_Skins/Challenge___Can_someone_make_me_custom_4_deck_3-1-2-4_skin__.html?page=4
geposted Sat 25 Jan 14 @ 2:26 pm
geposted Sat 25 Jan 14 @ 3:04 pm
Well, if i remove 2 of the 4 decks, and stretch the other 2, along with the mixer, then most likely we ll get a skin that will look similar to the 2 Decks default one..
Anyways, i don't think that its not that much necessary to have another 2 deck skin, with similar graphics and layout to the Default one. So i am afraid, i will reply with a big No to your request, unless of course someone else wants to take over your request and make a modification. In that case, be my guest :)
geposted Sat 25 Jan 14 @ 6:40 pm
True - it would LOOK similar but there's a few functions on your skin that aren't on the default including an extra hot cue, times for each hot cue, the ability to change the header of the track to show either wave or info, toggle to allow the sampler to be permanently anchored at the bottom of the screen etc... so it's more of a function based request even though I do prefer the overall feel to your 4 deck skin - it just seems smoother and more refined.
Well thanks anyway for taking time out to read my post
geposted Tue 28 Jan 14 @ 9:02 am
