Gemini Slate
RGB backlit pads, newly designed capacitive jog wheel, and a familiar layout designed to feel comfortable for all DJ’s from beginner to professional. The perfect companion for todays thin computers you can easily travel almost anywhere with the thin (25mm) and light SLATE.
Two good to be true
Two full-featured decks, two channels of mixing, two rows of pads, and multiple colors all in a thin but strong enclosure make the SLATE a dynamic and reliable controller portable enough for the most outrageous environments
All Inclusive
The SLATE’s DJ tools including pitch fader, key-lock, and advanced effect controls give you instinctive control. With 8 multi-color pads per deck to control hot cues, sampler, and on the fly auto loops all color-coded for ease of use. The full 2-channel mixer gives you constant access to the EQ, and dedicated Filter controls. Master RCA outputs, headphone, and microphone inputs give you all that you could need in when it comes to I/Os.
Immediate Results
The pre-mapped FX controls for Virtual DJ bring immediate results upon first use, while the fully MIDI mappable and high-resolution 14-bit controls give the SLATE the ability to easily be adapted for use with any of your favorite DJ applications.
Specifications
USB/MIDI software controller with built-in professional 24-bit PC/MAC audio interface
2-channel mixer with 3-band EQ, and dedicated Filter control on each channel
Pre-mapped FX controls for Virtual DJ
8 multi-function RGB pads per deck
Includes quick toggle for Hot Cues, Auto-Loop and Sampler mode
High Resolution touch-sensitive jog wheels
Responsive controls with high-resolution 14-bit MIDI
Midi mapping functionality over the entire controller
1/4” microphone input with Gain control
RCA master outputs and 1/8” headphone output
http://geminisound.com/product/slate
Gemini Slate 4
Power of Four
Two full-featured decks, Four channels of mixing, two rows of pads, and multiple colors all in a thin but strong enclosure make the SLATE 4 a dynamic and reliable controller portable enough for the most outrageous environments
All Inclusive
The SLATE 4’s DJ tools including pitch fader, key-lock, and advanced effect controls give you instinctive control. With 8 multi-color pads per deck to control hot cues, sampler, and on the fly auto loops all color-coded for ease of use. The full 4-channel mixer gives you constant access to the EQ, and dedicated Filter controls. Master RCA outputs, headphone, and microphone inputs give you all that you could need in when it comes to I/Os.
Immediate Results
Specifications
4-channel mixer with 3-band EQ, and dedicated Filter control on each channel
http://geminisound.com/product/slate-4
Two good to be true
All Inclusive
Immediate Results
Specifications
Gemini Slate 4
Power of Four
All Inclusive
Immediate Results
Specifications
geposted Thu 23 Jan 14 @ 7:39 am
Ho iniziato a creare i mapper per VDJ 8 per questi nuovi controller Gemini, stay tuned ;)
geposted Thu 08 Jan 15 @ 1:43 am
geposted Tue 17 Mar 15 @ 2:53 am
