I just bough the Numark Mixtape 2 - I used to have the IDJlive so I already had virtual dj LE ... So I deleted everything virtual Dj and put in the install disc for the new Virutal DJ LE for this dj controller. I'm getting the protection %I -- I've deleted everything I could. Why wont it work with damn CD in the drive.
geposted Thu 30 Jan 14 @ 5:43 pm
I believe you mean the Numark Mixtrack II ..not Mixtape, correct ?
You will need to make a clean installation of the LE version you are about to use. The most important part is to successfully delete the plist file.
Please follow the steps from this page .. https://virtualdj.com/wiki/Mac%20Clean%20Re-install.html
Note also, that only one LE version can be installed at a time. If you wish to use your iDJLiveII again, you will need to repeat the same process.
It is also recommended to register your new LE serial to your Account https://virtualdj.com/users/edit.html and download the latest available LE version from your Download Center. There is a possibility that the bundled CD includes an out-dated version.
Make sure you are entering the correct VirtualDJ LE serial (keycode) and not the serial of the actual unit.
If you still have issues after the above, please contact Support ..https://virtualdj.com/contact/
geposted Thu 30 Jan 14 @ 11:06 pm
