Using VDJ Pro, is it possible to interrupt just video of a music video going out to the TVs, and switch to a usb camera that appears on the TVs, then switch back to the video? Such as, music video is playing, I switch to a usb camera that is panning the crowd, then switch back to the video, while the audio never stops. Can this happen using just VDJ Pro? :)
geposted Thu 27 Feb 14 @ 11:58 am
A live video input? Not possible yet (I think) That might be worth a shout on the request board.
geposted Thu 27 Feb 14 @ 3:54 pm
Live video is possible via several plugins with the Pro version.
You can do a lot with video. Just to flash your video over the music video is as easy as turning on the camera plugin while the video is playing.
You can do even more with other plugins like screen and text layouts, transitions, etc.
In the picture, the ugly mug in the center is via a live video feed. The picture to the right is a slide show. You can define an area or panel to be fed from a deck video.
geposted Thu 27 Feb 14 @ 5:28 pm
I do it all the time but my USB camera does not PAN/Zoom.
I use a Logitech USB camera I think it was C70 something (it was the $99.00 one)
While the Video is playing on the outside source (T.V, Monitor, Projector etc..), I can switch to LIVE so people see themselves dancing.
You can switch back and your video will continue playing.
geposted Fri 28 Feb 14 @ 8:32 am
Hey Magic!, well just what do you switch, that's where I'm confused.
geposted Fri 28 Feb 14 @ 9:00 am
Just enable the Camera Plugin then disable (on/off), that's it.
geposted Fri 28 Feb 14 @ 9:13 am
this is the camera I use.
http://www.logitech.com/en-ca/product/hd-pro-webcam-c920?crid=34
geposted Fri 28 Feb 14 @ 9:15 am
My My, I should have known, here I had this big problem to solve and VDJ solved it long ago! So simple! Thanks Magic, I'll go check out your camera!
geposted Fri 28 Feb 14 @ 9:21 am
where is the camera plugin
geposted Wed 01 Jun 16 @ 2:50 am
where is the camera settings
geposted Wed 01 Jun 16 @ 2:53 am
