i know this sounds kinda strange... but would it be possible to use 2 controllers to be able to use for 4 decks?
geposted Thu 13 Mar 14 @ 7:29 pm
you can use as many controllers as you like in VDJ Pro, you can also use more than one of the same controller which traktor doesn't offer.
geposted Thu 13 Mar 14 @ 7:55 pm
how?
geposted Sun 23 Mar 14 @ 2:44 pm
If more than 1 controller are connected, and a 4 deck skin is loaded, then in CONFIG-->Mappers tab-->Mappers Options button, you will get an Option Deck assignment, where you can define which controller controls which decks
geposted Mon 24 Mar 14 @ 10:36 pm
this is so simple in pro I now have 5 controllers at once. In pro you load the drivers then plug in the controller and then go into settings and you can select what controller runs what decks.. 1-2 denon 3-4 pioneer or what ever. It is not possible in l.e or home.. as they don't have the settings like in pro..
geposted Wed 26 Mar 14 @ 10:42 pm
