I have been having a problem after playing for a 1/2 hour or so. I drag a new song onto a deck while playing a song and it starts playing by itself. The time line bar is not going either and the play button is flashing. Real problem when people are dancing. Both songs play at one time and I have to pause the first song.
Also when this happens if I open the sample tab the songs will stop playing. the only way I have been able to take care of the problem is to close VDJ and reopen.
Ideas?
Ideas?
geposted Sun 16 Mar 14 @ 6:44 pm
Seems like you have enabled the Prelisten Player of the BROWSER somehow, and by selecting the next song, you were actually telling the Prelisten Player to play/use the next one (setting Keep playing to change enabled as well).
the Prelisten Player stops if SAMPLER page is selected as well.
If you cant see the Prelisten Player, click on the "eye" icon next to the Search bar of the BROWSER and click on the "Show Prelisten"
geposted Sun 16 Mar 14 @ 6:48 pm
I will check that, not sure how though because I am just dragging songs in.
Thanks
Thanks
geposted Sun 16 Mar 14 @ 7:05 pm
