What I sometimes like to do when playing techno is to begin a loop at lets say 8 beats and then gradualy cut it down to 1/64. At 1/64 you get a cool sounding buzz. I've also heard Crhistian Varela using this but, he has some fine adjustable loop control. It isn't stuck to the common values (8,4,2,1/4,1/8 etc.) Could this be done for VDJ? I think yes.
geposted Tue 23 Sep 03 @ 8:27 am
Of course you can. You just have to create your specific shortcut the loop value you need :)
geposted Tue 23 Sep 03 @ 9:13 am
Yes, I know you can do that, but can it be done (in other words would someone do it :) with a slider in a plugin.
geposted Tue 23 Sep 03 @ 3:30 pm
