This is so strange. I've been using Virtual Dj on a mac with the mc-6000 for 2 years already and last night when i turned everything on virtual dj would not work with the mc-60000.I could use the sound card on the mc-60000 but not to control virtual dj with it. I had to play all night using my mouse to control virtual dj. Any ideas on what happened or what caused this.
geposted Tue 18 Mar 14 @ 12:44 am
DId you try to restart your Mac or re-connect the MC6000 on USB ? If it was a temporary issue, i dont think you should worry much, but i would recommend to replace the USB cable.
If its a permanent issue (not resolved with the above ways), we could proceed on troubleshooting.
Let us know
Let us know
geposted Tue 18 Mar 14 @ 6:16 am
I tried A NEW USB CABLE WITH NO LUCK.STILL HAVE SAME PROBLEM.
geposted Tue 18 Mar 14 @ 6:08 pm
Ok, so its the same story. MC6000 works on launch and stops working a few hours/minutes later ?
Please try to optimize your computer by following this ... https://virtualdj.com/wiki/Common%20Mac%20Performance%20Issues.html
Q: Is this happening only at a specific venue/place ? or not related ? it could be a temporary power drop issue (lost MIDI)
geposted Tue 18 Mar 14 @ 9:37 pm
Same issue. On PC. Started with the volume sliders not working. Cross fade did. Now nothing works control wise. have to use the mouse. everything is upto date on VDJ 7. don't like 8. win 7 pro
geposted Sun 06 Dec 15 @ 6:16 am
I'm using Denon MC 6000 mk1 + Mid 2012 Macbook Pro + El Capitan and my system sings...but I'm also using VJ8. How any professional could still be with VJ7 just does not sound right...Everything is better in 8. If complete re-install does not work, try 8 as a trial. If that works, at least you won't need a new computer.
geposted Mon 07 Dec 15 @ 1:37 am
If it started with something and then expanded to something more it would be a hardware issue. Perhaps the faders are worn out or the mainboard of the unit has issues. I would try on a different computer with a fresh install of VirtualDj and if that fails I would visit a service center
geposted Tue 08 Dec 15 @ 8:16 pm
