I am using VDJ7Pro and a DDJ-SR.
I want to adjust the frequency at which the low begins to cut. I would like to keep a little more of my mids in when I start pulling out my lows.
Is there a way to change that?
Also is there any way to adjust the taper of the EQ. It cuts the frequency very fast. When I turn the eq knob to the left about 20% it's about the same as turning the knob on my Rane mixer about 50%.
I understand that it's a full kill on the frequency but it just seems to get there too fast.
Can this be adjusted at all?
geposted Fri 21 Mar 14 @ 4:03 pm
Adjustable EQ frequencies were introduced in VDJ 7.3
http://www.youtube.com/watch?v=yIZgEdylkJQ
geposted Fri 21 Mar 14 @ 6:09 pm
Would options>Volume Faders :linear/quadratic make a difference on eq or is that exclusively for the volume gate(s)?
geposted Sat 22 Mar 14 @ 9:40 am
thanks for the link
geposted Sun 06 Apr 14 @ 10:01 pm
you wouldn't want quadratic curves on the eq as you would have to turn the knob to about 70-80% to get the real value to 50%
geposted Sun 06 Apr 14 @ 10:06 pm
