It's really weird but I have installed the Demo Version and it just closes by itself after almost 2 minutes (1.55).
I tested it listening to music, scratching, and even without doing anything and everytime it closes by itself.
Any ideas?
HELP!
Any ideas?
HELP!
geposted Tue 23 Sep 03 @ 10:39 am
          Since When did you use your demo version ?
    geposted Tue 23 Sep 03 @ 11:17 am
          Like DJ Morris suggested, how long have you been using your Demo. After a certain amount of time (20 days from first installation if I recall correctly) It is set to close itself after a minute or two as the trail period for its prolonged use is over.
Regards;
Redman247
    Regards;
Redman247
geposted Tue 23 Sep 03 @ 12:00 pm
          Even before the 20 days have run out if you install a newer version, it will think that you are trying to reset the trial countdown, so it will punish you buy setting the trial time left to 1 or 0 days.
    geposted Tue 23 Sep 03 @ 3:27 pm
          nscode that's false. It but it doesn't reset the time.
    geposted Tue 23 Sep 03 @ 4:13 pm
          Hmm.... maybe not on purpose, but mine got reset once and it happend to some other people to.
    geposted Wed 24 Sep 03 @ 6:35 am
          why does my virtual dj closes after 2 minutes, and this is the first time i have ever tried it, So why should I buy it if I can't even try it out. This is very bogus.Not happy with this.
    geposted Fri 24 Oct 03 @ 9:26 am
          If it closes after 2 min, you should have installed it more than 20 days ago..
    geposted Sun 26 Oct 03 @ 6:28 am
