I'm switching over to the Hercules DeeJay Trim 4 & 6 from Rane SL1 box
My Mixer is the Pioneer DJM-700
I've mapped the crossfader
Key O-CC11 Action 'Crossfader'
When I have either song playing 1 or 2, I can't cue unless I slide the crossfader slightly into the current song.
What is the mapper to get my cue's to listen without bringing the video's into the next song?
Thank you for your help
geposted Thu 27 Mar 14 @ 10:08 pm
There is really no need to map the crossfader of the DJM mixer or any other slider or button. Use that as an analogue dj mixer and use the Hercules to route each one of the decks to the mixer with the following Sound Setup.
Inputs : None
Outputs : External Mixer
Sound card : ASIO and choose the Hercules ASIO driver from the list.
You could map the crossfader fot eh DJM as video_crossfader, just in case you need to control the video transition individually.
In case you still need to use the DJM as MIDI mixer, you will have to ..
- Map the entire mixer (Crossfader, Volume, EQ etc)
- Have a different Sound Setup (with Headphones instead of External Mixer)
- Plug Headphones to Hercules Trim
Inputs : None
geposted Thu 27 Mar 14 @ 10:38 pm
