I've tried everything and for whatever reason in this version of Cue 7.4.1 I can not put on Key Lock. I use to use it all the time when mixing and its pretty annoying that I can't now. Any ideas????
I can provide you with specs of everything but I think it may just be the version of cue because it doesn't work on any laptop I have had it on and this is now for about 4 months or more I'd imagine. I've just been waiting to see if any updates were coming out but none have in a while.
Thanks
Thanks
geposted Sat 29 Mar 14 @ 10:05 am
go into the config->performances menu and make sure you don't have "pure scratch" enabled. If you want the best performance with the master tempo you should enable the "advanced algorithm" but be aware that it will use more cpu than the other options.
geposted Sat 29 Mar 14 @ 11:53 am
