Hi
I am trying to map my hercules rmx
I need my master volume slider to controll all the sampler volumes simultaneously.
can get some hepl?
The sampler volume action will activate the slider only on the first sampler.
Thanx
can get some hepl?
Thanx
geposted Mon 07 Apr 14 @ 1:10 pm
Apparently sampler volume can not be executed through master volume controls.
See discussion here - https://virtualdj.com/forums/159600/Hardware_Technical_Support/Mixtrack_Pro_sample_playback_volume.html
geposted Mon 07 Apr 14 @ 7:01 pm
The above link shows them trying to use sample when it should be sampler. This is probably why it didn't work for them.
Check out this thread:
https://virtualdj.com/forums/153632/Wishes_and_new_features/Sample_volume_auto_match_Active_Deck_volume.html
There are a few different solutions offered. They all seem to go along with scanning your samples with a utility like mp3gain to set them all at the same gain level.
geposted Mon 07 Apr 14 @ 10:19 pm
this is possible with Virtualdj pro full.
With Virtualdj LE is not possible to edit and customize the default mapper.
geposted Tue 08 Apr 14 @ 2:38 am
Ok
Thanx
Thanx
geposted Tue 08 Apr 14 @ 12:19 pm
