I do not know how to describe it, but it's something very odd, im trying to start the song from 1:20 mins and when i prees on play its starting on another time.. its seem to be a bug, It only happens when I use the the round deck (i dont know whats the name) . i try to uninstall but its the same problem.
i cant mix that way. try to update frimware but nothing work.. its a problem with the Virtual Dj program.. anyone know my problem?
thx.
thx.
geposted Thu 10 Apr 14 @ 9:56 am
Can you give a little more information as to your setup?
Controller type, virtual DJ version
Maybe register your serial number and compare your version to the one that will be available in the download center after registering.
Is the platter on your controller what you are refering to as the round deck?
Can you cue up the song at the desired start position and click on play? Does it start where you want when you do that?
geposted Thu 10 Apr 14 @ 1:27 pm
Try Config>options>Auto cue>disabled, maybe.
geposted Thu 10 Apr 14 @ 2:23 pm
You say you have an LE version, what controller did it come with? Please register your software, to be eligible for any updates, or bug fixes.
geposted Thu 10 Apr 14 @ 3:23 pm
