Hello! I need assistance regarding the Mix Desk Control (NUMARK), the crossfader is not mixing the videos, only music. How can I mix videos using this control? Thanks in advance for the help provided!
Moderated : Spanish message is removed. Please write only in English here or use the Spanish Forums
geposted Fri 11 Apr 14 @ 8:28 pm
Numark Mixdeck has an analogue dj mixer on the center. Only the decks (sides) are MIDI. So it cant control the internal mixer of the software, therefore it is not suitable for video mixing.
There are 2 ways to "mix" videos .
1. Map a button on your controller to perform the video transition (action=video_transition)
2. Have the AUTO enabled in the VIDEO panel of VirtualDJ (LINK set to OFF). The video will automatically crossfade to the playing deck, using the selected transitions). Cut transition is the most suitable, as you need a transition that is not displaying the other deck if the video crossfader of VirtualDJ is not at one of the 2 sides.
geposted Fri 11 Apr 14 @ 11:14 pm
