I have had an issue for a while. When I create a filter (automatic) folder say dayssincelastplay i get a ton of songs that I have never played. Even in the stock Played filter folder has lots of stuff i have never played. Any advise?
geposted Thu 17 Apr 14 @ 6:40 pm
put a number after your filter
days since lastplay<31
geposted Mon 21 Apr 14 @ 1:20 am
That was done. not the issue
geposted Tue 22 Apr 14 @ 8:07 pm
Are the values for last played correct?
Add a column for the last played counter to the browser and check it.
And/ or try this filter:
days since lastplay<31 and lastplay != 0
geposted Wed 23 Apr 14 @ 4:15 am
thank you for the reply. The values in the browser are correct. I will try the filter you mentioned tonight when I get to work. thanks again.
geposted Wed 23 Apr 14 @ 6:35 pm
That worked! Thank you sooooooo much!
geposted Thu 24 Apr 14 @ 10:11 pm
You're welcome :)
geposted Fri 25 Apr 14 @ 3:16 am
