sorry im posting somethig that has already been talked about.
i couldnt find it in the forms.
but i wanted to know it the Performance Pad for iRemote 1.0 can be resized or made for the iphone?
thank you
thank you
geposted Sat 19 Apr 14 @ 12:09 pm
guess not. thanks
geposted Mon 28 Apr 14 @ 7:20 pm
It possibly could be, but would be tricky to use with such small buttons.
The best options would be to create one, if you feel brave enough ;-)
geposted Tue 29 Apr 14 @ 8:46 pm
Performance Pad ??
are you already asking for vdj8 features for the iPhone remote app? at the time of writing this we're still with v7.xx
geposted Wed 30 Apr 14 @ 1:24 pm
Performance Pad is a skin for the iRemote app. It is unrelated to V8.
https://virtualdj.com/addons/16130/Performance_Pad_for_iRemote.html
geposted Wed 30 Apr 14 @ 1:28 pm
thank you. yea the buttons would be small. maybe not so many buttons but larger ones. can i make this with the skin creator?
geposted Fri 02 May 14 @ 6:31 pm
I see no reason why you couldn't!!
Best bet is to download the performance pad skin and that will give you the code you will probably need.
Start by creating you .BMP (picture file) it will need to be 320x460
geposted Fri 02 May 14 @ 6:40 pm
thats what i needed to know. ive made skins before but this is a whole new ball game. gonna give it a try. thanks djtouchdan.
geposted Fri 02 May 14 @ 6:59 pm
