Ai I missing something?
Is there a setting in VDJ that will protect the active deck while loading the other deck?
Some other software programs prevent this but I note the VDJ will load the new tune over the active deck while it is playing. Yikes!
Tommy
Tommy
geposted Mon 21 Apr 14 @ 6:32 pm
go to settings under security set to Ask. after that is all setup if you try to load a song while the deck is playing it ask you first if you want to stop it.
geposted Mon 21 Apr 14 @ 7:18 pm
sorry it loaded the pics backwards but you get the jist
geposted Mon 21 Apr 14 @ 7:19 pm
thanks!
geposted Tue 22 Apr 14 @ 5:39 pm
