I need the .xml file for the mapping for the DJ2GO to transfer from the virtual dj LE software to other software i wish to use. Does any one know where this is stored for the LE version as it is not in Mac/HD/User/Documents/Virtual DJ/ Mappings. Otherwise can anyone provide one. Thanks in advance!
geposted Tue 22 Apr 14 @ 1:17 pm
The mapping is built into the software (Natively supported) and is not available separately. It would also not work with other DJ software anyway because the mapping format is specific to VirtualDJ. To use it with other DJ software you would need to map it yourself manually providing that the other software supports MIDI mapping.
Custom mappers are also only available to registered licensed users who have purchased or upgraded to the full VirtualDJ Pro. They are not available to limited edition users. The DJ2Go is natively supported in the latest full VirtualDJ Pro v7.4.1 as well as the LE version that you received with the controller.
geposted Tue 22 Apr 14 @ 1:27 pm
