hello and good eve..
ever experience vdj 7 freezing during your set while the music keeps playing? anyone know a good fix for it? its a bit nerve wracking.. good thing i have a backup of my playlist on my iphone. i cue a track on my iphone and when the track on the frozen vdj is almost done, i mix in the cued track on my iphone and reboot the laptop. this issue started last week during a gig and it happened again just now while playing around.
i have a mbp i7 2.3ghz machine with 8 gb of ram and 200 gb of free space on my 500gb hd. i am running os mavericks. am using the pioneer ddj wego.
thanks for your advice!
warmly,
michael p
warmly,
michael p
geposted Wed 30 Apr 14 @ 11:44 pm
What else beside the Wego do you have connected with your Mac?
Do you use a external harddrive or a second harddrive inside your Mac?
geposted Sun 04 May 14 @ 7:21 am
thanks! no external devices connected, wi-fi and blue tooth turned off.
geposted Mon 05 May 14 @ 6:56 am
So, 1) ONLY the Wego is connected with your Mac and 2) no second internal harddrive?
geposted Mon 05 May 14 @ 7:37 am
I'm having this exact same problem, and it's making VDJ 8 unusable for me. It happens about once every 5-10 minutes. Doesn't seem to be any clear trigger that causes it to happen. The music keeps playing, but the interface freezes, mouse won't move, and system clock stops. It's happening whether or not I have a controller connected. No extra hardware plugged in, and I tried quitting all other open applications and it still happens. Running latest OS X (10.9.3) with latest VDJ 8 on a 15" MacBook Pro Retina.
I hope this bug gets fixed soon; I'm excited to use VDJ 8 but I can't until this is fixed!
geposted Wed 21 May 14 @ 5:45 pm
I got the same problem !!
geposted Thu 22 May 14 @ 4:18 pm
Build 1793 get my Mac to freeze completely(not only VDJ) for 1 min, music is still playing.
geposted Sat 24 May 14 @ 9:02 am
Same problem with build 1806
geposted Sun 25 May 14 @ 3:29 pm
Hello,
I am having the exact problem, when i play for about 10-15mins my mac freezes while the song is till playing. Is there a fix for this??
geposted Thu 29 May 14 @ 12:49 am
Yes I have the same problem. Is there a solution?
thank you
Martin
thank you
Martin
geposted Tue 03 Jun 14 @ 12:05 pm
There are couple of known freezes on the Mac side at the moment - hopefully these will be fixed soon.
We have no timescale for when this may be, but rest assured once a solution is found and confirmed, it will be released.
geposted Tue 03 Jun 14 @ 8:06 pm
GOOD, in OSX it freeze, in Windows 8.1/bootcamp it,s PERFECT
geposted Sun 08 Jun 14 @ 4:42 am
we really need this update as soon as possible, it is a shame that Mac users can not use VD8 correctly. It's very frustrating. we even does not know when the problem will be solved!!
geposted Sun 08 Jun 14 @ 7:56 am
staying on v7 until all known freezes are fixed. better safe then sorry
geposted Sun 08 Jun 14 @ 8:43 am
Same problem on mine. I won't be able to use this until the freezing is fixed.
geposted Mon 16 Jun 14 @ 5:50 pm
Last night I tried something and it worked. When my computer froze, I opened up VDJ7 and started a track on the other side. It seems I can use both versions and blend perfectly without having to close the other version. As long a I remember to turn down the volume in VDJ8 in that channel, I can play it in VDJ7 without anyone knowing the difference. This will work if someone really wants to use the new features of vdj8 but still have the reliability of VDJ7 as a backup. I then restart it and go back to VDJ8. It works on my DDJ-SB, I haven't tried it on my NS6 or NI Audio 8 yet.
15" macbook pro 2011
16gb ram
750 gb ssd
pioneer ddj-sb controller/
16gb ram
750 gb ssd
geposted Wed 25 Jun 14 @ 12:22 pm
With Build 1872 everything works perfect!
geposted Thu 03 Jul 14 @ 4:11 pm
Hi I am running a MacBook Pro mid 2015, 16gb,
Vdi8 is freezing on me to a point I have to shut it down.
I have plugged in it is ddj-sr and sometimes CDJ 2000
I also plug in a G-drive thunderbolt.. should redownload VDJ7 and us that until its fixed
geposted Fri 24 Nov 17 @ 3:59 am
warmly,
michael p
warmly,
michael p
I work for a larger wedding DJ company. We have 25 systems all running very decent hardware. Ive got VDJ pretty much dialed in at this point. BUT, something i cannot seem to prevent are random freezes when accessing the options or messing with the automix (Remove already played or changing the order) this is repeatable but random.
Anyway, the solution i found is to minimize (DO NOT "X" OUT TO CLOSE) the software and open it back up from taskbar and you'll be back in seconds. Try it on mac im sure its not that different. It works every time ON WINDOWS.. we dont use apple. If i figure anything else out i will report back.
These laptops power through stems and everything no problems. These issues are not hardware related. Also for anyone curious. Ive stripped these of all unnecessary software possible. Any big or little feature or program not useful for DJing has been disabled or uninstalled.
Hardware, Windows 11, AMD Ryzen 7 7735HS, 32GB DDR5 4800mt, AMD Radeon RX 7700S 8gb.
geposted Tue 29 Jul 25 @ 11:45 pm
