I have MIDI controller and I want to light up one of buttons (sync) when BPMs of deck 1 and deck 2 are not equal (so I know I have to change BPM of one of them) and then turn off the light when their BPMs are the same...
Example: I have song with 128 and 135 BPM, so it will light up, then I speed up the one with 128 BPM to 135 BPM, so it will turn off...
Can I achieve this somehow? I tried things like "match_bpm ? off : on", "var_not_equal 'deck 1 get bpm' 'deck 2 get bpm' ? on: off" but I still can't figure out how to do it, can anyone help me find solution? Because it does not seem to be anywhere.. :(
geposted Sat 10 May 14 @ 5:01 am
you must have a licence of vdj and you need this plugin to use it
http://fr.virtualdj.com/addons/12817/WatchDog.html
geposted Sat 10 May 14 @ 7:47 am
Thanks, that's nice but I was looking for a very simple solution without plug-ins and stuff like that... I'm sad there are some features missing even when they would take just a while to make...
geposted Sun 11 May 14 @ 2:29 pm
