1 - got excited
2 - downloaded pre release vdj 8
3 - it loaded up, i went to resize the screen, now VDJ is completely black.. even when i rebooted and tried to open it again..
I have teamviewer guys, and m online now, feel free to connect to one of my studio machines and see the huge bugs in action - its totally unusable.. :(
geposted Mon 12 May 14 @ 3:00 am
Whilst the software is browsing through files VDJ 8 won't allow any files to be opened so therefore if in the middle of a gig you click on a large music file VDJ 8 can not be worked with unless a folder has been previously loaded to the right hand side panel.
geposted Mon 12 May 14 @ 3:54 am
Do you mean while it's scanning?
geposted Mon 12 May 14 @ 3:57 am
I loving the new V8, however the BPM analysis does not seem as smooth as V7... Even tapping it out seems to be over the place...
geposted Mon 12 May 14 @ 4:09 am
I have the MAC version of VDJ 7.
I do weddings, so I will wait a few days before loading and using the version 8 on live events.. But, can I have both installed at the same time?
I want to have 8 to start practicing at home or when guests are not in the room, but i Stil want the secure feeling of version 7 never crashed on me..
When I feel confortable 8 is really 100% ok for me, I will make the full swich and uninstall v7.
So, can I have them both installed on my mac (not runnig both at the same time, obviously)?
Zorza
Zorza
geposted Mon 12 May 14 @ 4:59 am
Yes you can.
geposted Mon 12 May 14 @ 5:03 am
dydy1 wrote :
What is the new procedure to do that? How do you create a new device folder?
synthet1c wrote :
You might have to create the devices folder and put your definition in there if it's a new installation separate form VDJ7.
dydy1 wrote :
Is there a way to import my old mapping to VirtualDJ8? VJDJ8 does not recognize my Denon DNS-1200s!
just goto your vdj folder, right click and select "create new folder" then call it devices.
geposted Mon 12 May 14 @ 5:09 am
Yes. Decks were playing and I clicked on a folder which hadn't been scanned and VDJ8 wouldn't allow me to open any other folders untill scan had finished. A design issue which I can see being a liability which wasn't in VDJ7.
geposted Mon 12 May 14 @ 5:44 am
[quote=zorza100]I have the MAC version of VDJ 7.
Zorza[/quote
VDJ 7 won't work whilst 8 is loaded
Zorza[/quote
geposted Mon 12 May 14 @ 5:49 am
geposted Mon 12 May 14 @ 6:01 am
for the moment you can have V7 and V8 installed cause V8 is still Beta. Shure this might change someday....;-)
geposted Mon 12 May 14 @ 6:09 am
I hope not!
On my system I have Ableton Live 8 and 9 installed. Four different versions of Cubase. Three versions of Mixed In Key. Two versions of Mashup. Two versions of Max (For Live) etc. etc.
geposted Mon 12 May 14 @ 6:17 am
groovin this was just a guess.....;-)
Atomix will decide
Atomix will decide
geposted Mon 12 May 14 @ 6:22 am
Yes I realise it's a guess. :-)
geposted Mon 12 May 14 @ 6:23 am
Adion wrote :
[quote=sleeperawaken]
It's also possible to enable the function "showHorizontalSidelist" in options, which brings back the v7-style sidelist.
Where is this please?
geposted Mon 12 May 14 @ 7:14 am
Config, options. You'll need to close and reopen 8 for it to take effect.
geposted Mon 12 May 14 @ 7:18 am
In the Settings window, go to "Options", make sure that "Show Advanced Options" is checked.
Then type "sidelist" in the Search field.
geposted Mon 12 May 14 @ 7:19 am
like it
geposted Mon 12 May 14 @ 7:48 am
Is it possible to set output to -2db or -4db like in VDJ7, so we can avoid hitting the limiter?
Thanks
Thanks
geposted Mon 12 May 14 @ 8:06 am
FINALLY it works on Mac OS 10.7.5 together ( VDJ 8 & VDJ7.4 )
Awesome work guys thank you Atomix… Need to try some more test...
geposted Mon 12 May 14 @ 8:09 am
