Topic: Video options [SOLVED]
Where is the option in video to hide virtual dj logo on the bottom corner of music videos?
geposted Sun 11 May 14 @ 12:54 pm
Go to options in config.
Check the advanced box
Search video ;)
Go to the options, activate "advanced" options and type "logo"
You will find all the logo related options !
Glad I found this - spent an hour looking through the online manual and was getting tired of trying to figure it out and about to ask the same question - I think it shouldn't be hidden as an advanced option since Virtual DJ is now being pushed as a video solution and feel in a professional setting (wedding, club, etc) that logo would be tacky :-)
Of course I know we should stick with 7 as it's the most stable but I like using new shiny things...
