Topic: History [SOLVED]
The history I have saved of all my sets is no longer there. The tab is there but it hasn't migrated all the dated files from v7. Is there a way to fix this?
geposted Sun 11 May 14 @ 2:46 pm
version 8 uses a different folder now , named as History. Simply copy all the files from the Tracklisting folder (that version 7 was using )to the new "History" one, and relaunch version 8
Wonderful. Done and working. Thank you :)
