I just downloaded the Per-Release VDJ 8, But now I can get the Pitch Controls on the any of my controllers to work. " HELP ! " I've looked in the options & Tweaks and couldn't find any setting for it to turn on or off. I tried different skins and different controllers. Do anyone know where or how to fix or change the settings. Thanks.
geposted Sun 11 May 14 @ 2:58 pm
not skin related for sure ;)
in controller settings, use the drop down and choose "factory default" .. works then?
(if so, probably something with an old custom mapper you had..)
geposted Sun 11 May 14 @ 3:34 pm
It would help to state which controllers you tried.
geposted Sun 11 May 14 @ 4:12 pm
Thanks Norway,
I tried using the "factory default" option in the Controllers page, but it did not work, But what I did to fix it was : delete the mapping file in the mappers folder in VirtualDJ, then downloaded the original CUE/Numark mapping file from the Numark website and the Numark mapping file from VirtualDj download site. I put both of them in the VirtualDJ mappers folder. One of the work fine, the other don't, But I for got witch one I downloaded from where. But it working so I'll keep them both, problem solved.
geposted Mon 12 May 14 @ 9:46 am
