everytime i try to log in it wont let me. ive tried my virtualdj,microsoft and google ids and it keeps saying that i cant connect to virtualdj servers. ive rebooted my computer,ive logged out of vdj 7 and still nothing
geposted Sun 11 May 14 @ 3:09 pm
use your virtualdj id.. that work?
(google and ms id will identify you only if same email as with vdj purchase.. or if you add them in your profile http://www.virtualdj.com/users/edit.html )
geposted Sun 11 May 14 @ 3:11 pm
I never take my gig laptop online, so I can't register it :(
geposted Sun 11 May 14 @ 3:13 pm
just contact support and we'll sort that with a special solution for that ;) ,
http://www.virtualdj.com/contact/index.html
geposted Sun 11 May 14 @ 3:29 pm
i tried it with my vdj id and nothing......
geposted Sun 11 May 14 @ 4:07 pm
Try changing your password and trying again.
If not you may have to contact SUPPORT
geposted Sun 11 May 14 @ 4:08 pm
You have to delete everything Serato, lmmfao!! Im playing, do what Dan said and it should work.
geposted Sun 11 May 14 @ 4:10 pm
Password is case sensitive.
geposted Sun 11 May 14 @ 4:46 pm
tried it all. even changed my password
geposted Sun 11 May 14 @ 5:20 pm
Are you able to log out of the website and log back in?
It should be exactly the same information.
geposted Sun 11 May 14 @ 5:21 pm
Did you add your MS or Google IDs to your account and try to log in using those?
geposted Sun 11 May 14 @ 5:22 pm
so when i try to log in with my vdj id i get this
geposted Sun 11 May 14 @ 5:44 pm
and when i log in using my google id i get this
geposted Sun 11 May 14 @ 5:45 pm
and i dont get it cause obviously if im cont connected to the internet i wouldnt be able to be here.........
geposted Sun 11 May 14 @ 5:46 pm
Did you get a firewall warning when you first loaded the software?
If you have a firewall Virtual DJ would of asked for permission to go onto the internet. If you refused that then this is what the problem is.
Make sure that you don't have any curious firewall blocking VDJ from accessing the internet.
geposted Sun 11 May 14 @ 5:49 pm
nope no firewall warning
geposted Sun 11 May 14 @ 5:56 pm
Maybe this is the solution for you:
geposted Sun 11 May 14 @ 5:57 pm
It certainly sounds like something (probably a firewall) is blocking VDJ from accessing the internet.
Do you have windows Firewall enabled or anything similar.
geposted Sun 11 May 14 @ 5:59 pm
I've got the Windows Firewall on and it didn't/doesn't affect VDJ 8 here.
geposted Sun 11 May 14 @ 6:01 pm
