DOWNLOAD HERE
Designed for iRemote to take advantage of the new sampler in Virtual DJ 8
- 16 Trigger Buttons
- Bank Select
- Play Mode (On/Off / Stutter / Unmute / Hold)
- Volume Control
- Output Select (Master or Headphones)
As always with my skins, i appreciate your thoughts and comments.
Thanks for looking and downloading!!
geposted Sun 11 May 14 @ 3:25 pm
          Will it work on any/all iOS versions?
    geposted Tue 13 May 14 @ 5:20 am
          Just iPad at the moment.
Will look at an iPhone/iPodTouch version but the iRemote app needs updating to support iPhone 5 screen size and up.
geposted Tue 13 May 14 @ 5:57 am
          What S/W build for the IPad ?
    geposted Tue 13 May 14 @ 6:00 am
          So long as iRemote runs then it should be fine.
    geposted Tue 13 May 14 @ 6:04 am
          That's what I was asking.
OK I'll give it a try.
geposted Tue 13 May 14 @ 6:28 am
          Hi
Tried to add this today but VDJ stops working when I click on Change Remote Skin. Any thoughts and help most gratefully received?
Many thanks
Many thanks
geposted Mon 01 Jun 15 @ 7:04 am
          Hello, I hope it does not bother the author, I take the liberty to translate and update the skin that I think is great and it works very well but it lacked the Spanish language and a touch of design, if the author authorizes me I upload it to google drive and I give the link
       geposted Fri 27 Dec 19 @ 1:57 pm
