I see all the individual sonique plugins but is there a way (as was possible in v 7) to set the sonique plugin as the default plugin for audio? Plus can I adjust how long the visualizations play before it switches to the next one.
geposted Sun 11 May 14 @ 4:34 pm
config -> options -> tick advanced -> videoAudioOnlyVisualisation
Currently there is no way to cycle the visuals - hopefully this will come, either as a plugin or native support.
geposted Sun 11 May 14 @ 4:36 pm
Is this the same with slide show?
geposted Sun 11 May 14 @ 4:38 pm
Slideshows has a shuffle option built into the plugin.
geposted Sun 11 May 14 @ 4:41 pm
What a pity. It was a great feature. I hope thar in the near future this feature be implemented.
geposted Sun 11 May 14 @ 6:30 pm
What was?
geposted Sun 11 May 14 @ 6:32 pm
The ability to automatically assign the sonique folder and the program automatically changes visual every 45 seconds as an example.
geposted Sun 11 May 14 @ 8:49 pm
We have requested a rotation option for audioOnly and sonique.
geposted Sun 11 May 14 @ 8:50 pm
You could always see if this one works for you too:
https://virtualdj.com/addons/16711/Milkdrop.html
geposted Tue 13 May 14 @ 5:31 am
just saw an image of this in another thread Scott, gonna try this out pronto... cheers
geposted Tue 13 May 14 @ 5:48 am
SBDJ wrote :
Great! Works fine!
geposted Tue 13 May 14 @ 9:36 am
anything for a Mac?
geposted Tue 13 May 14 @ 12:04 pm
Not yet, but soon...
geposted Tue 13 May 14 @ 1:05 pm
SBDJ wrote :
I downloaded it and when I try to install I get "Software not found. You must install the software first. Please check on virtualdj.com for more information"
Any ideas?
geposted Tue 13 May 14 @ 3:13 pm
mikadad wrote :
anything for a Mac?
It would be nice if we could use quartz compositions.
geposted Tue 13 May 14 @ 3:50 pm
Any ideas?
Any ideas?
I've just reuploaded the installer, please redownload and retry.
geposted Tue 13 May 14 @ 3:54 pm
mikadad wrote :
anything for a Mac?
It's on my to-do list to investigate.
geposted Tue 13 May 14 @ 3:55 pm
