Topic: DDJ -s1 - Page: 1
Should the DDJ -s1 show up under audio/Cards
geposted Sun 11 May 14 @ 4:42 pm
It will only show up if the configuration was set during the beta testing and software build.
I know a man who will probably know.
Thanks you sir
I'm also trying to figure out the jogwheel sensitivity the default is
1.000000 Ok I would like to make it less sensitive how do you change these
numbers? Sorry to sound like an idiot but I'm not that computer savvy would
love to have a slider there
Not the controller expert but i think making the number smaller makes it more sensitive.
e.g. 0.500000
But you can try that and if its wrong then change it back and increase it.
Phantom or DJDad are the 'technical' controller experts
@ audio0000
Unfortunately we didnt have available sample units for all the supported midi controllers. So some of them may still not offer a pre-defined Audio Setup. But it can be added in the next update. Please install the necessary ASIO drivers for the unit, create the proper Audio Setup (with Master, Headphones and the ASIO drivers selected from the drop down list) ans post a screenshot of that Audio Setup here. We will sort this very soon.
Default=1
2= Increased sensitivity
0.5= Decreased sensitivity
Thanks George - Dan
i need a screenshot of the Audio Setup with ASIO and the details from the right side visible if possible. thanks
Ok in v7 my jogwheel sensitivity = 420
in v8 how would you write this out would it be like this 0.000420?
No you need to increase it. Try changing it to 2 and then work from there.
If you can sort djdad out the screenshot then he can get the setup organised.
That is what I have up top for my audio set up
Can you drag out the right hand side - need to see everything in the righthand box. ;)
I thought the S1 had its own ASIO driver?
this should be easier to see
I think the forum is resizing images now.
It always did. Anything more than 800pix wide gets resized
djdad
Can you see what you need to see sir...?
Maybe make a PrntScrn and then edit it down to just the right side then.
Phantom Ok
in v8 I put it to 0.420000
Would that be the same thing....?
No. It's different now.
Edit:
420 in v7 = 0.205 in v8 (value/2048)
91%
