Been playing with V8 tonight. So far, the sound is amazing, the smartmix is even more amazing then it was before, and loving the skin resizing.
In the automix window, if I select "shuffle", it actually does shuffle the playing of the playlist songs, but it in V7.4, it would shuffle the actual list, so you could still see the order that songs were going to be played. It does not seem to do this in V8.
I did see the "will play at" header, which is awesome btw. I tried sorting on that, but it did not seem to change anything.
Am I seeing this right?
Thanks in advance!
Ward
Thanks in advance!
Ward
geposted Sun 11 May 14 @ 8:06 pm
I'm going to report this as a bug i think.
If when shuffled the times changed, then fine.
Or if the order of the songs change like in v7 then fine.
But it does neither.
Thanks for letting us know.
geposted Sun 11 May 14 @ 8:28 pm
There's definitely stuff not working right with the Automix.
A lot of wedding DJ's use the automix.
The Shuffle function needs to physically shuffle the songs in the list. How else are we going to know what's coming up in the next few songs.
Someone comes up to the DJ booth to request a song already in the automix and we can then say the song comes up in about two or three songs.
If the list doesn't shuffle that ability is gone.
Also, I can't seem to reorder the list once the automix is playing. Being able to moving a song up or down in the list is crucial.
In one occasion I couldn't even place a song in the list either. Automix needs to work Atomix!
geposted Sun 11 May 14 @ 11:13 pm
Update:
Shuffle the list is still a problem.
Reordering in the Automix does work when loading a saved playlist.
I initially right clicked a virtual folder and loaded that in automix and there's no re-ordering possible there. Workaround is to load the virtual folder in the automix and save it as a playlist and then load the saved playlist in the automix to allow re-ordering.
geposted Sun 11 May 14 @ 11:33 pm
Can you check something for me? I tried dragging a song out of auto-mix and couldn't; I had to right click & choose remove. I tried it on the sidelist/playlist and the auto-mix side screens and couldn't drag a song out. I'm using it on a Mac.
Cheers,
Nick
Cheers,
Nick
geposted Mon 12 May 14 @ 12:04 am
You can also use the delete button on your keyboard to remove songs from the automix.
Dragging a song out is indeed not possible.
geposted Mon 12 May 14 @ 1:03 am
Thanks for your response, I realize it's not a big deal, but is this something we can request to add?
Cheers,
Nick
geposted Mon 12 May 14 @ 1:06 am
I am testing on pc windows 7. I cannot rearrange song list when in automix, which was a great feature in v7. I also cannot drag a song from the playlist which was a great thing on v7, would love to have this on v8. I am loving v8 thanks team great work!
Keep em dancing
Keep em dancing
geposted Mon 12 May 14 @ 1:38 am
Update: I tried the delete button that works fine, so i guess i can just delete to remove from the automix. Thanks
geposted Mon 12 May 14 @ 1:42 am
But i really would like to be able to rearrange songs in the automix. I also can not change the fade point as i was able to do in v7. I could just click the fade indicator and slide it back to another fade out position. Any input would be appreciated. Thanks
geposted Mon 12 May 14 @ 1:51 am
In the manual there is a whole description on editing the mix points.
geposted Mon 12 May 14 @ 2:04 am
I was reading the automix section and it shows editing the beat counts, 4, 16, but that is not what i mean. If a song is playing and i want to mix out in the middle of the song all i had to do was drag the mix point to where i wanted to mix out and there would be a smooth fade out and the next track starts. thanks.
keep em dancing
blkjk is this what you were referring to.
(Automix Length
Length used for the Automix Fade types. Lengths are 0 seconds (cut), or 1, 2, 4, 8, or 16 seconds fades using the full crossfade)
keep em dancing
(Automix Length
geposted Mon 12 May 14 @ 8:50 am
djernie2 wrote :
I was reading the automix section and it shows editing the beat counts, 4, 16, but that is not what i mean. If a song is playing and i want to mix out in the middle of the song all i had to do was drag the mix point to where i wanted to mix and there would be a smooth fade out and the next track starts. thanks.
keep em dancing
keep em dancing
Edit
I notice that (mix now) will do this, so I guess I will use this method now. Thanks
geposted Mon 12 May 14 @ 9:01 am
Is this what you were referring to?
(Automix Length
Length used for the Automix Fade types. Lengths are 0 seconds (cut), or 1, 2, 4, 8, or 16 seconds fades using the full crossfade)[/quote]
geposted Mon 12 May 14 @ 9:11 am
You can edit the automix POI's for it to always mix at that point on the track. For immediate mixing, I mapped a button for automix_skip.
geposted Mon 12 May 14 @ 6:36 pm
For immediate mixing, I found out if I double click any track in the list, it will mix it in right away.
geposted Mon 12 May 14 @ 7:00 pm
Here is another problem with automix.
When dragging and dropping a song into the box sometimes it doesn't show up. Then when you drag another song in it appears.
Anyone else seen this?
DJ James
DJ James
geposted Mon 12 May 14 @ 7:55 pm
Yes, this was already reported.
But unfortunately it's very hard to reproduce because it doesn't happen always.
So very hard for the developer to fix that issue.
geposted Tue 13 May 14 @ 3:55 am
DJ James
DJ James
Yeah i have had that a few times
geposted Tue 13 May 14 @ 8:02 am
shure that all tracks you used are scanned and added...?
geposted Tue 13 May 14 @ 8:04 am
