Topic: Quick question
Quick question does VDJ run in the back background when you close it I had to end the vdj.exe process to close the program alway down. Should it be like that?
geposted Sun 11 May 14 @ 10:41 pm
No, it shouldnt do like that, ans most likely its audio drivers related. What sound card do you use for your audio Setup ?
Ddj- s1
Same thing happens with ASIO drivers used in the Audio Setup or only when WASAPI is used ?
