Topic: Denon 6000 and NS7 II
First have to say thanks to the team, Its so smooth!
Denon 6000 - everything was good - no issues after about an hour of play -
NS7 II - setup took a little longer. Slip mode doesn't work, activating video effects cant be done by using the assigned buttons. I have to do it with the touchpad.
Why can't I access my Nvidia card in the video config, it just shows the intel card. it ran smoothly, but I would like to use the NVidia card. Had no issue just using an old monitor to show video on like some other users were having just plugged in as usual and it worked!
geposted Sun 11 May 14 @ 10:53 pm
