Hi Have found a couple of things, Karaoke runs slow on the mac stutters the lyrics etc, and wont read .zip karaoke files
Karaoke runs fine on windows in bootcamp but still no read or .zip karaoke files come up in browser, on the positive side video works much better on the mac now:)
spec here if helps
2.3ghz I7 2013 macbook pro
16G ram
Nvida gt 750m 2048mb
512Gb ssd
spec here if helps
16G ram
512Gb ssd
geposted Mon 12 May 14 @ 2:05 am
Make sure these options are set to yes for karaoke
geposted Mon 12 May 14 @ 2:09 am
Go to options, check "Show Advanced Options" and search for "zip"
Set "showzipkaraoke" to yes
geposted Mon 12 May 14 @ 2:18 am
cool all good now and works fine :)
how can i delete post etc if i accidentally post in wrong place?
geposted Mon 12 May 14 @ 2:26 am
my karaoke lyrics graphics are having problems on the PC their lagging and locking up has anyone else had this issue as well?
geposted Tue 17 Jun 14 @ 5:21 am
