Topic: VDJ8 & Denon mc6000 MK2
Hello
impossible to run my mc 6000 mk2. it is recognized in vdj8 but impossible to play a title.
geposted Mon 12 May 14 @ 3:57 am
So long as you setup the sound settings correctly, it will work. I have the same setup. Search this forum.
Please specify your Operating System.
Does the special button you get in the Audio Setup of CONFIG creates the correct one ? Can you please post a screenshot if you re not sure ? Keep in mind that you need to press APPLY after changing the Audio Setup.
