Topic: Msc 6000
One issue I have come across using mu denon mc 6000.
When using the toggle switch in the middle when using it to press down on it would build a play list of songs for me on the right hand site . When pushing down on 8 it's loading the empty deck ??????
geposted Mon 12 May 14 @ 7:26 am
Sounds like you need to remap it.
yes i confirm
you need to remap the button
And how do I go about that ???
gimme a mins...please ;)
ok in Virtualdj 8 just press shift + press the browser encoder to add songs in the playlist zone (automix)
Hi moramax. Can you explain a bit more where is this shift on vdj 8 I am not the best at this stuff thanks for you patience
Shift should be a button on your controller.
Located top left of your jogwheel.
Got it mate thanks
