Topic: Denon DN-S1200 mapping issues with V8!
Denon DN-S1200 mapping, was not imported to V8. Is there any plan in the near future to make compatible with V8?
geposted Mon 12 May 14 @ 7:52 am
They are no longer supported with v8.
Maybe a user will write a mapping. But don't know if it will run with v8.
Is there a way to import your old mapping? You guys should still make all these players compatible with the software.
The 1200 is listed in the available devices, so should be supported AFAIK.
That is great news!
Any ETA on when this update might be available?
It's listed in the current build - if you right click in the mapper devices window, you can show all controllers ;)
SBDJ, I see it in the list of all the controller but V8 is giving a message saying they are not connected when they are!
OK, I got my old Denon DN-S1200s working now with VTDJ 8! The procedure was as such: In Mac, go to Document folder and open the Mapper folder and copy which ever mapper you are trying to use with the VTDJ 8 and go to Device folder and paste the old mapper there. Reopen VTDJ 8 and voila VTDJ 8 will now recognize your Denon DN-S1200s. Not all the buttons are working at this point because of many changes with the new VTDJ 8, but a few still works like on VTDJ 7.
I still have a problem using Mac with VTDJ 8 and Denon DN-S1200s. Deck 1 is shown on the Denon Display as deck 2 vs! Is there a way to fix this? Also the titles of the songs on the decks no longer show. I suppose Denon support need to tell us what is the new scripts for those functions.
