Same problems as listed above...
also when needle drops the wave form stretches until it reaches normal speed, the pitch rapidly climbs from minus to plus
on needle drop or when play is pressed on CD player song starts off slightly under pitched until it catches its normal speed
geposted Fri 29 Aug 14 @ 10:09 pm
Nobody else having the pitch jumping issue like me?
This is why we need a buglist Atomix, so we know if the problem is our setup or your software!
geposted Sat 30 Aug 14 @ 4:42 am
What do you mean by pitch jumping?
geposted Sat 30 Aug 14 @ 4:54 am
I'll make a vid when I have time today (working atm)
in the config window under timecode you can see timecode speed, it jumps between 96 & 104% witch makes my pitch jumps during playback
geposted Sat 30 Aug 14 @ 5:03 am
http://www.filedropper.com/timecode12014-08-30-12-21dasouth2004b1941
timecode signal, this should tell you all
I'll still upload the vid asap
btw, using vdj timecodes oredered in 2004-2005 maya44 usb & shure447 on 1200's mkII
pitch was set to 0 on decks
geposted Sat 30 Aug 14 @ 5:25 am
damn posted it in the regression thread :D
don't do 10 things at the same time, i'll fix it
both pitches at 0% no buttons pressed.
Same track on each deck, lined up on same position, at the end you see the pich jump & they drift away
https://www.youtube.com/watch?v=SZD-tcnb3c0&feature=youtu.be
edit : just saw that autobpm match was on, turned it off & it seems better but not 100% yet
geposted Sat 30 Aug 14 @ 6:27 am
ok i am having the problem with when u load a track.and also when u load a track it does not play while the record is moving i have to press the cue button or pick up the needle and put it back down for it to start playing.And sometime when i load a track it start to load and the deck goes blink and i have to reload the track again.
put i started to mess with it today and i have to say a good improvement for timecode vinyl so far fingers are cross
thanks to the dev team for listening i know i said a lot of - thing because i was frustrated .but lets keep on getting it right with this new timecode engine and fixing the little bugs i mention here .so i rate timecode now at 88% good.but let me keep testing it.
i dont know put sticker drift was good for today and the pitch was not bad to i took it off to reset the pitch on load to no and it seam to be ok.
but before i get to happy let me keep testing it.
the bad
1- the tracks it wont start to u pick up the needle and but it back down when u are changing a track.
2-sticker drift
3- scratching on smart or absolute mode u have to have good needle for it not to jump and the timecode record should not be warp
4- when moving the pitch on the turntables vdj is slowly responding on how u are moving the pitch on the turntables it not accurate so when u move the pitch on the turntables vdj take a longer time to respond so when it does it take u off beat.
the good
1- The track starts normal its does not jump in no more .i am very happy about that.
2-backspin is good
3-Scratching is accurate
4- no more jumping when scratching on relative mode.
5-pitch not jumping no more when holding the record slowly and moving it back and forward.
the bad
2-sticker drift
the good
2-backspin is good
geposted Sat 30 Aug 14 @ 7:50 am
Time code got worse for me using CDJs. Look at the pitch slider each time i press stop and play on the decks, It affects the sound briefly until it catches up..... In this same video I showed what happens when you try to load another track while one is already playing or change the song.
Something not quite right where needle drop is concerned I never had this pitch problem on previous builds
geposted Sat 30 Aug 14 @ 10:09 am
This time code is worse..I'll be making videos...
geposted Sat 30 Aug 14 @ 10:58 am
I had to revert to the previous build, this was unusable... don't get me wrong some things have improved but the new bugs introduced makes it unusable for my set up
geposted Sat 30 Aug 14 @ 11:28 am
What do you mean "needle drop" in relation to CD players?
What is supposed to happen when you load a track with the CD players? What mode are you using smart, relative, absolute?
geposted Sat 30 Aug 14 @ 2:06 pm
