Topic: info tab
Is there away to take off the info tab....
geposted Mon 12 May 14 @ 9:26 am
Did you mean completely remove from the skin, or undock it from the skin an drag it somewhere else?
Or just collapse it?
You can't remove it completly in the full browser. You can close it.
Skin developers can now split the browser into sections so yes it can be removed in a custom skin.
thanks ......
