This is my easy :) keyboard mappin for v7 I can't it to work on the action deck in v8.....
<?xml version="1.0" encoding="UTF-8"?>
<mapper device="KEYBOARD" author="Atomix Productions" description="Keyboard" version="705" date="25/09/2012" priority="-50">
<map value="TAB" action="deck active select" />
<map value="1" action="loop 1" />
<map value="2" action="loop 2" />
<map value="4" action="loop 4" />
<map value="5" action="loop 8" />
<map value="6" action="loop 16" />
<map value="7" action="loop 32" />
<map value="P" action="play_pause" />
<map value="S" action="pause_stop" />
<map value="E" action="effect active" />
<map value="SPACE" action="reverse" />
<map value="," action="eq_kill_low" />
<map value="." action="eq_kill_mid" />
<map value="/" action="eq_kill_high" />
<map value="DELETE" action="browser_zoom" />
<map value="RIGHT" action="deck 2 timecode_bypass" />
<map value="LEFT" action="deck 1 timecode_bypass" />
</mapper>
</mapper>
geposted Mon 12 May 14 @ 9:48 am
try changing the version to "800"
"browser_zoom" is no longer supported so that can go or change it to something else.
Everything else looks ok.
geposted Mon 12 May 14 @ 9:51 am
ok thanks only ones not working now is these
</mapper>
</mapper>
geposted Mon 12 May 14 @ 10:35 am
does changing them to deck left timecode_bypass and deck right timecode_bypass fix it?
geposted Mon 12 May 14 @ 10:37 am
Will there be an action to replace this, or an update to the default skin that enables the browser to be full screen?
Basically, full screen browser mode is my default usage at gigs, and if 8 has scrapped it then I'll be sticking to 7.
geposted Mon 12 May 14 @ 10:40 am
There won't be action to replace it.
But browsers can be skinned much more now. They can even be put in a window so you can move it around and put it where you like.
geposted Mon 12 May 14 @ 10:41 am
did not work.......
did not work.......
geposted Mon 12 May 14 @ 11:32 am
all is good now
geposted Mon 12 May 14 @ 11:51 am
What was wrong with it?
geposted Mon 12 May 14 @ 11:57 am
I had to do a reboot for some reason.... I don't understand but it worked
works fine now with
works fine now with
geposted Mon 12 May 14 @ 1:11 pm
