Topic: Audio output problems
Hi guys, finding myself unable to use my onboard laptop speakers with the new version.
Here's my output setup...
And here's the error I get....
I've enabled Wasapi shared in advanced settings, it had no effect.
geposted Mon 12 May 14 @ 9:59 am
Any ideas? Doing my head in trying to work it out
Try enabling wasapiShardedMode in config
I have (see bottom of my post) still no good
Virtual DJ is NOT RELEASING sound card drivers to other devices in windows 8. If I tab out of vdj i should have FULL control of my usb soundcard for youtube, etc
Do other programs output sound without any issue whilst VDJ is open?
Your post is not related to this issue!
But your answer here:
Cauthers, I think you need to reboot. I had that same error and a reboot sorted it.
Thanks groovindj I'll try that. No other audio (firefox/windows media player) works when vdj is open but resumes when i close vdj.
Cauthers wrote :
No other audio works when vdj is open
That's the wasapisharedmode option as mentioned above. Exclusive mode (default) prevents other software accessing the soundcard.
