Topic: SUGGESTION: Remove tracks in Automix?
We used to be able to hit the delete key to remove the tracks that are in the automix. Is it possible to add that back into the program? It was rather convenient.
Thanks!
Scott
geposted Mon 12 May 14 @ 10:53 am
You still can hit delete.
Well i can anyway.
Sorry Dan, it does not work for me... using a Mac.
Ah ok - yes i was using a PC.
Will boot my Mac up and have a look.
Thanks Dan... I know it's minor but it is an important thing.
I can confirm that this isn't working on Mac. We will get it resolved ;)
Perfect, thanks!
Again, not a huge deal but something... haha
Thanks again!
Scott
Is there any plan to be able to drag songs out of the automix list back into the browser area to remove them like you could in 7? it was just very quick for me doing karaoke shows to be able to do that and i haven't been able to replicate that action on 8.
Hey everyone-
Hit the fn key and delete & it'll work.
Cheers,
Nick
I brought that up already, Atomix confirmed that you can't remove songs by dragging songs out. Hopefully this will be a fix sometime soon.
Cheers,
Nick
+1 on the ability to Drag songs out of Automix list for 8.1 or whenever.. Took me some time to figure it out.
+1 would like to get... drag out of automix window = remove song from automix , single or multiple songs hi-lighted though Ctrl Click or Ctrl A
(As it Used to Be)
Peace
Me too - also the Forum just started changing to French on me - Western Canada = Anglo not Franco - Fix please!
Drag out would be so useful.
