OK my screen resolution is 1366 x 768 and the icons, tabs and waveform all are blurry, Even any text is also slightly blurry.
See screenshot below.
You can download the entire full sized by going to http://mocksite.x10.bz/scrshot.jpg
geposted Mon 12 May 14 @ 3:19 pm
+1 - Posted same issue - my res is 1600x900 ( native for my laptop display ). VDJ7 was much more crisp than v8.
geposted Mon 12 May 14 @ 3:35 pm
go to graphic card settings, and set it to best quality (not fastest).
That should sort it
typically , something like this where you move the slider to quality
http://www.legitreviews.com/images/reviews/1169/intel_gpu_gui2.jpg
That should sort it
geposted Mon 12 May 14 @ 3:42 pm
That should sort it
That should sort it
That worked!! You Da Man!!
geposted Mon 12 May 14 @ 3:56 pm
I use a Mac and have the same issue. I don't believe the Mac has such an app to control this.
geposted Mon 19 May 14 @ 1:07 pm
what graphic card you got on your mac?
geposted Mon 19 May 14 @ 1:44 pm
I should have been specific... The laptop contains an Intel 4000 stock video card. (Not a discrete nVidia or ATI.)
geposted Mon 19 May 14 @ 4:04 pm
yes, its an issue with the lower end cards, and you should have something similar to the intel settings in the post above..
Not sure where it is at the mac, but maybe someone do
geposted Mon 19 May 14 @ 4:18 pm
I'll have a look, however everything else is crystal clear, just not this. (I feel this is an issue with the images, not with the computer.)
geposted Tue 20 May 14 @ 8:07 am
I looked around and also confirmed with Apple that the settings are not adjustable as they are on the PC.
I would assume that this is a quick skin fix?
geposted Tue 20 May 14 @ 12:15 pm
Same problem with MBP 13'' with 1280x800 resolution
geposted Tue 19 Aug 14 @ 12:04 pm
From what I was told, if you are not on a retina display (none of my MBP's are), then you will have to deal with the blurry icons _or_ use a different skin.
There's a group of us whom are debating rebuilding certain skins and locking them to the most common resolutions.
geposted Tue 19 Aug 14 @ 9:22 pm
That sounds just great. In case u need help with skin testing, count on me.
geposted Sun 24 Aug 14 @ 12:00 pm
