Topic: Silent Updates Question.
Hello,
I heard about the silent updates feature in VDJ8 and wanted to know if the Mac version has this? I have left VDJ on for about an hour and reopened it and haven't got the 628 update. (Currently on 626..) Is it something wrong I'm doing or is there a link to this new update? Thank you.
geposted Mon 12 May 14 @ 4:59 pm
Some updates may be PC only and others Mac only - nothing to worry about.
The part after the dot (.626) should not bother you... It will update only when needed. The part BEFORE the dot (1748) is the current build number... :)
Thank you for the quick reply.
