Is this a multi-select function like the Scan BPM's is? I have 250 selected and only one is downloading...
![](/image/2631/134905/Screen Shot 2014-05-12 at 3.19.51 PM.png)
geposted Mon 12 May 14 @ 5:22 pm
its right there no? "download to cache" ;)
works for multi selected files..
geposted Mon 12 May 14 @ 5:25 pm
Multiselect does work - not sure whether 250 is too many though.
You can now view your download queue also:
![](/image/55013/134907/2014-05-12_2325.png)
geposted Mon 12 May 14 @ 5:26 pm
Ok, there must be a limit i hit then, I just did 20 and it works
geposted Mon 12 May 14 @ 5:29 pm
Only one is downloaded at a time. the rest of the files you have chosen to download, will be in a priority queue (subfolder in the content Unlimited folder) and will be downloaded as well, once the previous one is finished.
I just tried 6 here and downloaded fine. Of course, there is always a chance that the songs for some reason are not available (especially if those come from Netsearch)
Could you please advise what did u type in the Search field in order to reproduce your issue ?
geposted Mon 12 May 14 @ 5:34 pm
Yup just ran across that, and it just gets stuck there and does not move on automatically, I have to cancel that d/l for that file so it will move on
geposted Mon 12 May 14 @ 5:35 pm
If they are all red globe icons they should be ok
The pink ones are Netsearch
geposted Mon 12 May 14 @ 5:36 pm
How do I get my cached items from content unlimited over to Virtual DJ 8 ??
geposted Tue 13 May 14 @ 3:06 pm
All sorted myself guys just needed to refresh the DRM's lol
geposted Tue 13 May 14 @ 3:12 pm
