im a pro user,and have noticed my usb mic will not work with vdj 8,but works fine with version 7,so i was wondering if their was a change that had to be made to get it to work??? vdj 8 read it but when u go to hit mic button on a hercules 4mx console it lights up but i have no mic...also is it required to uninstall 7 before installing vdj 8?????
geposted Mon 12 May 14 @ 5:30 pm
You don't need to uninstall VD7.
Can you post a screenshot of your audio config screen?
geposted Mon 12 May 14 @ 5:34 pm
geposted Mon 12 May 14 @ 8:47 pm
When you click apply does the mic initiate or the box stays saying click apply to initiate?
geposted Mon 12 May 14 @ 8:52 pm
it initiates it ,but i get no sound from mic ,very weird,works fine on 7,lol
geposted Mon 12 May 14 @ 9:09 pm
geposted Mon 12 May 14 @ 9:18 pm
geposted Mon 12 May 14 @ 9:53 pm
just discovered my headphones don't work either in vdj 8...ill just use 7 till the final version is out with no bugs..to aggravating for me to be a tester when nothing works,no mic,no headphones,skin not compatible, cant use the effects tab and sampler etc... some effects won't work.. i do realize they need updated so not really complaining about that,but mic and headphones should work and do not...keep chugging away at the bugs....
geposted Tue 13 May 14 @ 12:08 am
