Anyone know how to disable or turn off live feedback recommends in vdj 8..
geposted Mon 12 May 14 @ 6:42 pm
There is currently no way to turn the Live Feedback off.
geposted Mon 12 May 14 @ 6:45 pm
you should add this feature, i don't want to have "live feedback" too.
geposted Tue 13 May 14 @ 1:20 am
Ditto. Please allow it to be disabled.
geposted Tue 13 May 14 @ 2:36 am
+1 Please !!
geposted Tue 13 May 14 @ 4:44 am
The option to disable has been requested.
geposted Tue 13 May 14 @ 5:24 am
DeadFeedback!
geposted Tue 13 May 14 @ 5:28 am
Definitely, allow the option to turn this feature off!
geposted Sat 17 May 14 @ 9:20 pm
IF you are running the most up to date build there is an option in settings for this.
geposted Sat 17 May 14 @ 9:26 pm
Could you please tell me where. I've looked all over, thanks.
geposted Sat 17 May 14 @ 10:26 pm
Config -> options ->select advanced -> search liveFeedBack
geposted Sat 17 May 14 @ 10:36 pm
Personally I don't mind it. it reminds of songs I perhaps have not heard for a while or did not consider would go with the track currently playing. I don't use it very often, but it is unobtrusive right there at the bottom of the screen minding it's own business.
geposted Mon 02 Jun 14 @ 3:26 am
Thanks TouchDan! Sometimes it has decent recommendations but it mostly throws me off
geposted Fri 04 Sep 15 @ 5:54 pm
