Topic: will sbdj profiles work?
wonder if the profile add on will work?
it just copies the settings file I think.....anyone test it?
geposted Mon 12 May 14 @ 7:28 pm
The Profile Switcher was actually dealing with registries in order to save/load/restore settings. Its now much easier to do that, as its one single file. I am sure Scott will update his Plugin very soon, or maybe another user will write one. Should be easy to do.
No, it won't work.
I'm not even sure its needed now we have sound and mapper profiles?
