In v8 during the transition the screen appears Black until its time to show video 2 (when the transition has completed)
It appears to me like its not loading my custom bitmap, but its still doing the same with your bitmap too.
loading up v7 and checking the transition still works on my system.
geposted Mon 12 May 14 @ 8:15 pm
A lot of v7 plugins are not v8 compatible, and this is one. I've reworked a *lot* of them and will be uploading them. Some have been integrated into the core of v8 instead, so I won't be updating those.
geposted Tue 13 May 14 @ 4:01 am
So will you be updating this plugin? The is the one I use the most or is there a way to accomplish what this does from within v8 now??
geposted Tue 13 May 14 @ 4:33 am
I will be updating it, yes :)
geposted Tue 13 May 14 @ 5:19 am
Many thanks SB you're the man!
geposted Tue 13 May 14 @ 5:30 am
geposted Tue 13 May 14 @ 6:56 am
you are a legend with your plugins Scot, this is what sets me far ahead of the rest of the local djs..
geposted Tue 13 May 14 @ 11:25 am
The updated version (which works on 7 and 8) also works with the fade to black on volume sliders, which can give you a cool effect ;)
geposted Tue 13 May 14 @ 11:44 am
not the best video on the right for this example, but clearly youve been working hard on your pluggins. Great work :)
geposted Tue 13 May 14 @ 1:04 pm
Not working again in vdj 8, build 1820
moving video crossfader has no effect until faded 100% to next deck then it shows what deck 2 is doing..
(like 0% <-----0%------>100%) if that makes any sense to you Scott..
geposted Tue 03 Jun 14 @ 8:54 pm
did few restarts and same fifference..
[Fixed in 1828]
[Fixed in 1828]
geposted Wed 04 Jun 14 @ 9:21 am
what is the highest resolution for the graphic file, Scot??
geposted Sat 25 Oct 14 @ 8:25 am
