Topic: Zip Files
Can it read zip files like 7 does so far it will not as far as I can tell.
geposted Mon 12 May 14 @ 11:57 pm
it can but you must enable it in your options. you have to check the advanced tab and there's an option for zip files. you search for it by typing zip into the search box.
Thank you
The more i use this the more I am liking it.
